JD 420 crawler hydraulics
RustyR
Anybody know what hydraulic pressure one of these runs at? Wondering if it would run a Davis backhoe that needs quite a bit of pressure to run it.
I think you would be okay on your hydraulics but I would worry about the final drives. Those drive casings aren't very strong. The 40 and 420 drive cases were a weak point on them. 440 had a beefed up case. They had very good hydraulics. Don't know how big you back hoe is but I would check with an old jd dealer about it. I have had 3/4 420 crawlers There a good little crawler if you use them for what there designed for. As far as the hydraulics I think it would work. Just my 3 cents worth. Norm
