Hello, I have removed the wheel and tire and the end cap exposing the 3 gears, axle plus the gear on the end of it, and the outer gear(for lack of a better name) all inside the hub.The outer gear is bolted and safety wired. The axle appears to be able to pull out, but I have not done that yet. I need to get to the wheel cylinder because it is leaking. Can someone walk me through this? I don't want to experiment and cause myself any unnecessary grief and I would like to learn the correct procedure the 1st time.
Today I bled the brakes and felt some pedal but it lost pressure and fluid and I had a big leak coming from this one drum. I may need to address the other wheel cylinders too since they are all probably the same age.
Thanks
Thanks
