Mid 70's case 350 dozer
Meknikal33
New User
Dozer was running great, when all of the sudden I had no
forward or reverse. Pulled on left turning lever and nothing
happens, but when I pull on right turning lever the dozer
moves, In forward and reverse. I have an idea what it might
be but wanted to see if anyone has had this happen and what
the fix was.
That sounds like there is something broke between the right brake and the sprocket,drain the final drive on the right and see if there is any pieces of metal in it.
AJ
(quoted from post at 06:31:14 11/09/15) That sounds like there is something broke between the right brake and the sprocket,drain the final drive on the right and see if there is any pieces of metal in it.
AJ
Thanks AJ, I'll check the oil on the right side, I found the manual, my father had It stored.
I had something similar happen. Broken axle. Loosened track, removed axle nut pulled track and sprocket out them removed parts in place to get to axle. Found a used one and all is good. Don't know if this is it but sounds like what happened to me.
Finally got a chance to work on the dozer, pulled the track off
and pulled case half of of final drive, the coupling inside the
axle housing had all of the splines stripped out. All other
pieces look good. Thanks for your help. I thought it would be
either the axle or coupling. Just had to do some exploratory
surgery. Thanks again
