kumotsu pc 60-7 excavator
460anger
I need to change the controls to A style anyone know how?I was told I had to switch some hoses?
serial#49383 if that helps
Thanks
IF it does not have a pattern changer valve Yes you CAN do it at the valve by changing lines but you DANG better get someone that know what they are doing or you will get things crossed up and never get it back right. Color coded zip ties are your best bet and a service manual.
According to the parts catalog that machine should have a pattern change over valve,check your handbook.
AJ
