Jcb mistake
Jcb backhoe not going in reverse intermittently. Traced problem to forward reverse lever. Removed lever drilled out rvits took apart found bad micro switch. Soldered in micro switch from radio shack still didn't work. Turns out common terminal is in different spot should have ohmed new micro switch before installing had to resolder. wires in new spot on switch. . Even though switch looked same should have checked continuity before putting in
