I am having a problem with one of the steering clutches on my HD-3. It will not release. I have had the steering clutches stick before and was always able to get them free by pushing against a stump while holding back the levers.That hasnt worked this time . The right side lever does not move as far as the left side, which is working fine. I took off the seat etc so I could remove the cover to the RH clutch/brake housing. It seems the amount of movement on the right side lever is the free play and a small amount more which is basically taking up the slack in the linkage. The throwout sleeve itself barely moves, which is why the clutch wont release . Nothing I could see looked broken or out of place.Not sure if there is anything else to try short of removing the clutch. Any help/insights would be appreciated.
