CMONTGOMERY
New User
I have a case 580 SK that is stuck in the forward position. This is the second time this has happened, the first time it was stuck in the reverse position. I removed the floor plate to gain access to the forward/reverse valve on top of the transaxle. I disconnected the shift linkage and removed the detent so the spool could move freely but that didn't change anything. The spool feels like it is hitting something metal, it is a hard stop. After turning the spool and pushing and pulling, it suddenly freed up. I reassembled everything and started the machine. As soon as I put it in the forward position, it got stuck again. The machine runs fine and I can shift it through all 4 gears in both forward and reverse position. I just pulled the valve body off the transaxle hoping to find a problem. Even after removing it from the transaxle, the valve was still stuck in forward. As soon as I turned in over and laid it on my work bench it freed up and would move through all 3 positions (forward, neutral, reverse) again. I removed the spool and cant seem to find anything that would cause the problem. I am wondering if the spool is worn allowing side movement inside the valve body which is causing the spool to get stuck. Can anyone offer any suggestions? I am at a loss... I have researched this issue and cant find anyone talking about it on the web. I believe that the valve is a Berg Warner but cant find any information on their site either. I originally posted this in the Case & David Brown section but realized that wasn't the best location (this is my first time posting).
