Went to work on my case 310 today. Put a shut off valve on the gas tank. Hooked it all up. No leaks. works fine. Put a new alternator on it. Went to start it and it clicked. So I went through the cables, etc. Still no work. Checked wiring. Got 12 volts on them. Still wont try to start. Replaced the ground cable. Still wont work. Put jumper cables on starter. wont move. Jumpered starter solenoid. still wont move. Took starter switch out and start button. Replaced couple wires that looked bad. still wont start. Pulled spare starter off the shelf. Had to take it apart and clean it up to get it freed up. Put it back together. Put jumper hot cable on post and ground cable to the case and battery post. starter would not do anything. Got ------ off and slammed to jumper cable to the ground post of battery. What did I hear something. Did it again and the dang gone starter worked. Could it be my problem all along was in my ground cable. Took the ground cable off. sandblasted it and put it back on. tried the spare starter and it works fine. Hooked the battery to the main starter. didn't work. checked voltage where it is bolted on to the frame. 12 volts. checked the area around the cable. zero. Theres my problem. Moved the cable to a different location. Scraped all the paint off with new bolt. Hooked up the starter switch and button. Spins her like a top. My wife once told me that when the lord was passing out the brains I must of thought he said trains and hopped a ride. Must have been SLOW FREIGHT. Cause it was no zepher. Have a good day. Norm
