Where are the filters located for the transmission oil? One or two filters? Oil used should be special oil for transmisions? We will drain the oil, change filter(s) and want to refill with correct oil. Have 5 gallon cans of oil available at NAPAp>Hydaulic system for the loader and backhoe. Is there a separate reservoir for these two hydraulic systems?
What is the capacity ( gallons ) of oil used in the transmission and I assume the differential uses the same sump for oil
