MF200 parts help
rnrracing
New User
Hello,
I have a Massey Ferguson MF200 crawler Dozer.
I am wondering if anyone can point me in the direction of some parts. the coupler that is in between my hydraulic pump and the front pulley on the motor stripped out. I pulled the pump off and it has a splined shaft on one of the gears that meshes with a splined hub that is bolted to the front pulley on the motor. I need both of those parts. the only part I can find a part number for is the flange that bolts to the front pulley (976 220 M2) but my searches come up empty. does anyone know where to find these parts. I would think they would fit other models also. Thank you for your help.
last 200 i had i just changed out the pump and made a new coupler . just found a pump with the right bolt pattern and shaft length and a spline that i could a female end for cut old one off and welded new one on a lot cheaper then OEM and at that time i could not find the parts and that was 20 years ago. if i recall Baum Hyd was a big help
Thank you. I may have to go that direction if I cannot find the parts. I was hoping someone had a broke down machine with some extra parts they don't need. I might also need the two drive gears for the tracks. Mine are pretty worn.
