D6 9U cat dozer
jim9004
New User
I bought a 1962 D6 9U dozer. It has a hydraulic Blade. What kind of hydraulic fluid does it use? Most importantly where is the reservoir located?
If you have a hydraulic blade the reservoir should be in front with the pump and you could used the same oil then motor or telus 32 or 46
