Fuel Pump for an Allis H4 CRAWLER
pinball
my fuel pump started leaking gas out a small hole on my H4 ALLIS CRAWLER. Only leaks when running. Suspect diaphragm is bad. Allis shows REBUILD KIT Number 4058971. Fuel pump part number is 4058966. Thought about putting an electric fuel pump on it but wanted to keep original if I can. Parts stores are no help. Anyone have any information on these. Thanks Norm
(quoted from post at 09:55:17 09/23/15) my fuel pump started leaking gas out a small hole on my H4 ALLIS CRAWLER. Only leaks when running. Suspect diaphragm is bad. Allis shows REBUILD KIT Number 4058971. Fuel pump part number is 4058966. Thought about putting an electric fuel pump on it but wanted to keep original if I can. Parts stores are no help. Anyone have any information on these. Thanks Norm
I saw on this site , someone said there is a Allis Chalmers or Fiat Allis Dealer I think he said in Mo. He said this dealer had a lot of Allis Chalmers parts . Maybe this will bring attention and you will get feed back. Good Luck on Allis Chalmers parts , they are becoming past History .
Your best bet is going to be to take it off and find the nearest auto parts house that has a book with the pumps in it. (((usually NAPA and Oreilies are the only ones with books))) and look until you find one that matches what you've got. It's not always easy, but I've had good luck doing it this way for awhile now.
