Case 1000D ip ?
TGP
1000D with Continental 4 cyl. Diesel and
Roosa Master injection pump.
Double seals leaking allowing fuel into
Crankcase.
After I pull the ip can I then pull the adapter
Block install those hard to get correct seals
Then reinstall ip as a complete assembly?
Thanks
Tom
Do yourself a favor and don't remove the adapter , rotation
sets the back lash to the cam gear and if you pull it there
is a hardened washer under the adapter shaft.
george
