Case 310b backhoe hose help plz
Skidduh
New User
I just got a 310 that the backhoe was seperated from, I got the back hoe installed back on the tractor but not sure where the hoses go... There is 3 places on the backhoe valve body where hoses go to. There is one on the right side that says (pump) so I'm thinking it goes to the main feed from the pump. Then there is 2 on the left side, one of those says (commercial) and the other says (pressure). Is commercial the return? And do I join the pressure hose to the pump hose? Does anyone have a 310 they could post some pix of the lines? Thanx for your time!
a shot of my 420B,,, should be close to what you have,, one line comes from the pump other goes to power loader valve then return to sump,,, But now that I keep thinking there is a three hose one too,,,, I will dig out my service manual,, think it shows both in there
cnt
Case nutty, have u had a chance to check out yr manual? Any info about the 3 hose valve body would be greatly appreciated. Thanx for yr time. Ben
Sorry forgot you not sure if you are checking this post anymore if you are post back or e-mail me @ stan2670@collinscom;net, I found I think what you need
cnt
