580 super E hydraulic pump
it looks like the hydraulic pump in my 580 super E has lost a shaft seal. anyone have any tips for getting the pump out? appreciate the help. thanks
unbolt the tin work around the radiator,, should give you easy access to it then,,, I have changed radiators in a hour or so on them pump takes a bit more as you will need to drain the hyd tank first or you will have a oil bath
