CASE W 14 PAYLOADER CAB HOLD DOWN BOLTS
lenray
Any one out there with a Case W 14 with a cab. My cab is loose and I don't understand how the hold down bolts work with the 4 corner bolts that have a steel bushing that is installed with the bushing being longer than the thickness of the cab floor. Probably haven't explained that very good, but if you own one you probably understand what I am writing. thank you
Sounds like it is either supposed to allow the machine to flex a bit as many early rops did by being loose or it is supposed to have rubber washers in there for same reason
