Re: Fan belt change - Hyd pump removal required?
dozerbill66
09-10-2015 17:00:39
[quote="AJ."](quoted from post at 12:35:54 09/10/15) No you do not have to move the pump,undo the four 7/16 bolts holding the coupling to the pulley and push the coupling towards the pump,put the new belt over the fan and then through the gap at the coupling,,lace the belt around the pulleys and put the bolts back in the coupling,adjust the belt,job done. AJ , I never tried it that way , I will try it next time , I have three 450s.
