Neg or Positve Ground
pinball
I have a case 310D crawler. Im not sure if its neg or positive ground. I think its positive. What is the danger if you hook the battery up wrong. Thanks for reading.
I have been breaking this 310 down to semi restore. Its been awhile since I removed the battery. I did hook a new battery up to get the tracks back on. I put the cable from the starter to the positive side. I plan on putting a new 12 volt alternator on it and I think that will be positive ground. I did start it up with no problems. so if its right or not I am not sure. thanks norm in missouri
Very best way to tell is to look at top of your coil and see which side [- or+]is hooked to points.Ground will be the same. Hoss
If you are going to a standard alternator you will make it neg ground when you do the conversion. The starter doesn't care. It will run.
Rick
