Konatsu d38 dozer trans pressure light
mhudgins
I just purchased a d38 dozer and the light is on for the trans pressure. I've changed fluid and filter and cleaned the mesh strainer/filter under the floorboard. Is there a pressure switch that could go out . Previous owner said its been on for years
Also where would yall suggest a service manual from
Thanks
On the top of the transmission filter you should find a pressure switch,remove the wire from it,connect the ground of a test lamp to the terminal and the other end to a power source,start the engine,if the switch is good the test lamp will go out,if not the switch is faulty.
AJ
