case 188 and 201 engine cast oil pan
i was wondering if the oil pans for a 188 and a 201 will interchange i put in a 660 combine 201 g motor in my 580 ck 1969 and realized that i need a cast pan or something to fill the void below the block and bell housing i have a shuttle transmission and the steering stabilizer bar also mounts to it i know i need a cast iron oil pan i meashured the stamped steel oil pan on the 201 it is 24 inches the motor that came out of the tractor was a 159 g and it is at the motor rebuilders
