steelhorse
New User
Hey I need a little advise. I found a D -8 H dozer
The under carriage is 90 % it's been sitting
For 4 years. The owner died but his wife is wanting it gone .
The last time it was ran it got hot and when they went to start it
Back up it would only run for about 30 seconds and then it would
Quit. So I put the batteries in it and it turned over and started ,I
Watched the gauges and the oil pressure went to the green and so
did the fuel pressure . But it shut down after about 30 seconds. After you let it set for 5 minutes it will start up again BUT it will not throttle up or down . The throttle linkage all works great and so does the decelerators linkage. I chked a couple fuel lines going to the motor and they were producing fuel. They drained all the water out of the machine so it's dry. I'm thinking that when it got hot may it messed up something in the injector pump or something is sticking on the decelerator but I'm not really sure.
I can buy this old D- 8 for a cheap price ,so I will have some room for repairs. They thought the motor was blowed up because it wouldn't run for over 3o seconds. But the motor turns over really easy! Has anyone got any suggestions ? I hate to see this nice old dozer just sitting around. It's in great shape !
Thanks for any help !
