Pecosallis
Been trying to start this TD 340 crawler. Had started it a while ago and got it on and off a trailer. Now I cant start it. I have a new battery but cranks very slow. I took out the injectors and fuel does squirt out the holes and engine turns over pretty good. when even one injector is in it is like the compression does not let the engine turn over. I was thinking maybe the starter is weak and doesnt have the cranking it needs. Checked the voltage prior to cranking 12.81 and while cranking 11.5. I have jumper cables directly to the starter and frame (Cleaned off good). Thanks for all your suggestions.
