H 3 Crawler
I have a A/C H 3 Crawler loader. it has been working fine , yesterday all of a sudden, no noise or grinding, the right track quit working, won't turn either way, the left one works fine? the reverser works fine. any ideas where to look first? It pulled real hard at first then freed up, now won't turn, Thank you , Ron Cutler 219-771-1343
Most likely will be the upper pinion gear in the final drive but could also be splines in steering clutch. Listen for unusual noise and then go to turning wrenches.
Thanks for the help. it made no noise, left track works fine, the right one just quit moving?
all I can think is that something came undone in the clutch drive assy. I just got it in the garage, so now i can take top off brake assy. and maybe see what is unhooked. Ron Cutler
