newhollandnut
You seem to know your way around cats well as I'm sure others but I've been looking at a d5g the oil pressure only runs around 20 psi the salesman says his mechanic says it's fine because is not about pressure it about volume which I'm sure is partly true but how would you know about the volume it is moving? Would you be afraid of it or is there anything I should look for to do with the oil pressure? I've only seen pictures from a buddy that was in the area cause the machine is several hours away. It has around 9000 hours with a rebuilt blade and under carriage. Said it was used to made pads for oil wells in North Dakota it whole life. Thanks for the input
