MARK ROBKE
My 955k had a problem one time a while back(it stopped moving),where transmission oil fluid migrated into the rear section=the steering clutches compartment.I posted on here and was told to clean the screen-that it would be covered with brake lining material.I cleaned the screen and drained the rear section and put the oil back into the front section,and all was fine.It happened one more time,and I cleaned it again.Now it has a new problem=the oil has went to the forward section-I guess this is the converter section? So-new question-what happened this time,where do I drain it,how do I fix it,does the belly pan need to come off,how big/bad of a job? I am trying to sell it since I don't need it any more and was using it for the first time in several years to make sure it is good to go,and now I find a problem-oh well,no one was calling anyway!Any help will be appreciated,thanks,Mark
