Weight of a CASE W 14 PAYLOADER
Case construction website shows 5912 lbs but I would have thought much more. Equipmenttraderonline has one for sale and list it at 24,220 lbs which should be much closer to correct.
17K ish, hauled them on 10 & 12 ton tags ok.
The case site has operating & load cap #'s
backward. B models 17,700 ish.
There are a few different W14 listed and they are all within the 15K lb range for a standard machine,the ones listed with a serial # have a few letters in front of the number.
AJ
Thanks for the info. fellas. Got the W 14 home and fixing a few items.
One big item is no BRAKES. There is an air blower on the back of the engine that is run off a belt from the fan pulley. That belt is missing.
Is this blower--air supply---just for emergency if the engine stops or does it help in the entire braking process.
The master cylinder is also empty. Would appreciate any help.
