Char Lynn Orbital Steering Valve 211 1002 001
lenray
I have this valve on a CASE W 7 Payloader--Took it some apart--not much but concerned I might have gotten it out of----TIME..
Any of you fellas have any info. concerning the timing of these units????
Will try to post a pic.
I have resealed some of those valves and never had any trouble with any timing,the main thing to do is scribe a two match lines from top to bottom as it is most important the valve is assembled as it was,the usual reason for having them apart is to replace the seal on the input shaft at the top,blank off the ports and clean the outside of the unit,keep your hands and tools clean,lubricate all the parts with the fluid/oil used in the system and you should have success.
AJ
