Impaladave64
New User
It has been running perfectly but would not start this morning. I have checked the fuel system all the way to the screen where the fuel supply line enters the injector pump and I have good flow into the pump. The return line is also clear and I verified that the pump turns when the engine is being cranked. When I loosen the fittings on the high pressure side going to the injectors I don't see any fuel leaking when cranking the engine. Does the pump need rebuilding or is there another reason for the problem. It has the cable that mechanically (no solenoid) stops fuel flow when shutting down the engine and this appears to be working correctly.
Thanks for any help that can be provided,
