Just brought home a T-340 IH loader so the other mini dozer (OC-3/HG) I had is going up for sale - looking for advice on a reasonable price for it and any suggestions on any Oliver/Cletrac specialty boards that might be good to advertise it on.
I was never able to find a sn to verify the year or exact model, but the consensus when I asked here is that it's a OC-3/HG machine.
The engine has been replaced with a Willy's Jeep flathead 4. The tractor runs and drives well, with all gears working. Blade hydraulics work but are weak - I suspect the pump needs work although when I pulled the cover off there was no obvious significant wear. There is also a slow coolant leak apparently from pinholes in the radiator core. It's not enough to cause problem running it, at least not for the 1-2hrs I have, but it will drain down over a couple days and need to be filled before using it.
UC looks in decent shape to me, though I have little experience - please take a look at the pics below and let me know what ya'll think.
I've looked around for similar tractors to price, but it's hard to really get a good feel with the variation in tractors and regions. This one looks in decent shape and runs/works, but I don't think it's really a restoration tractor with the engine swap and such. Also hard to say what the engine swap does - on one hand it seems like it would be a much easier engine to find parts for and has more power, but on the other hand it's not original.
Thanks,
~John
Thanks,
~John
