I will be removing one hydraulic cylinder off the 4-in-1 bucket on my Cat track loader. The lower pin (2"dia.) that has lots of contact with dirt is seized in place. I'm interested in knowing from those of you that tackle this issue from time to time which procedure works best. To put heat to the two pin mounts would require two torches or you you end up heating the pin as well if it doesn't happen quick enough. Our region is so dry that fire risk at extreme and the machine is in the forest...therefore hesitate using torches (I don't want to be on the news for causing a forest fire). I don't have a portable pin press either. I wish to avoid expanding the end of the pin by too much from a sledge hammer...what would you guys do? Thanks.
