Case 450 pulled torque converter fiber gear shot
Bob was right the fiber gear was wasted have to hunt down the fiber gear.made a oops pulled flywheel off and when cleaning it I see there are timing marks on it.how do I put it back on.
(quoted from post at 16:35:53 07/11/15) Bob was right the fiber gear was wasted have to hunt down the fiber gear.made a oops pulled flywheel off and when cleaning it I see there are timing marks on it.how do I put it back on.
Hey can you call me now , I didn't get your phone # ?
hey bill tryed to call bad phone service and Internet at campground where I work.anyway pulled torque convertor not to bad except working headfirst.i dont have the lancing wire or flex plate just the plane Jane.flex ring has teeth inside and out it fell apart when I took it out.probley 10,000 hours on it.have a guy that parted out some 450s he thinks he might have one.if not I'll call case.part manual sucks it look like the gear but it shows it where the flywheel starter ring is .my torque convertor label is d35012 but the part manual that's shows the right one is d45565.case page says the older convertor sometimes uses the newer flywheel.looks like my part number is d52317.dont know if I'm right but it says that fiber gear is the only style these used the the ring changes on other models .any idea.also flywheel stud pulled out I should put 4 new ones in.looks like 7/16" X1-1/2" fine tread.wonder how hard to locate those ain't like the old days Napa would carry all that stuff.thanks dave
