Hello Forum.
trying to diagnosis a problem with a 1975 case 480 Construction king backhoe/loader. has a G188D engine using a Roosa Master injector pump. Used it about a month ago and was running fine. went back to use it just a few weeks after parking it and it will only start on starting fluid. has fuel to the pump, and manual shutoff is working correctly. Pulled the timing plate on the side off to check to see if the shaft was working. When I pulled the plate, about a cup of diesel came out the port. Couldn't find my mirror to inspect to see if the shaft is turning but with the diesel coming out of the timing plate: is there a problem with the pump or is this normal... ?
