Dresser Loader w/ broken fiber ring???
ErinNick
New User
My company has an old Dresser loader that we are trying to get back up and running. We are looking for the inside adapter ring that bolts onto the flywheel and connects to the transmission. My Google search has revealed that this may be called a Fiber Gear, but I'm not too sure just yet considering we need it to be steel.
We are having trouble locating this adapter ring, so I'm throwing out here to you guys hoping you know where I can go to get a replacement! I've attached some pictures to try and help.
The piece in the picture appears to be metal, not fiber. That said, Twin Disc uses a drive ring like that attached to the flywheel to drive their clutch discs.
I did a search for a "6625a drive ring" and came up with quite a few hits. Here is a link to one of the sites, as well as to the whole search.
Drive ring, Search
(quoted from post at 18:08:29 06/25/15) The piece in the picture appears to be metal, not fiber. That said, Twin Disc uses a drive ring like that attached to the flywheel to drive their clutch discs.
Drive ring, Search
Thank you sooo much!!! I googled the item number multiple times, but since I didn't know what the part was called, nothing would come up.. guess Google isn't as smart as it thinks it is! I really appreciate it!!
