Working in the dirt the other day on a td150 drott and had a sudden loss of power , while babying it , trying to get back to the barn it stalled. I fired her back up started fine run high
for a few seconds and started a slow stall, tried feathering , no good . So I figure it may need fuel filter s . I pop drain on fuel tank to see if I had water , no water . I move to filter s ,
primary was filthy , secondary not to bad. I replace both , bleed at filters . Didn't help same problem . Starts right up full throttle runs for about 30 or 40 second s and slowly dies.
Thinking it maybe pump. (Stanadyne ) but if pump was bad would it start at all? Could not find a obvious bleeder on pump itself .
Any advise would be appreciated.
Thanks.
Scott
Thanks.
Scott
