JD 500A hydra hose problem
The hydraulic hose from the right power steering cylinder blew, I cant figure out how to get it off. It goes to a block in the frame, I don't see any way I can turn a wrench in there. Does the block come out, or can something be removed?
Thanks for any help, Ken
I've never changed that hose put have changed plenty similar ones,one way I used to do it is if I could is cut the hose,take off the armor and slid a ring wrench over the hose,the other is the crows foot or a flare nut wrench,the parts drawing shows the hoses are attached a block,the block appears to be held on with bolts,if you opt to loosen/take off the block try and loosen the hose first so you don't fracture the steel line attached to it.
Good luck
AJ
