Case 850 E wont turn left in high gear.
Penntech
New User
Hello, I am working on a case 850E that will not turn left when holding the let brake in high gear. The left tract stops when you press the medal but the right track wont push. Also when you drive into a pile in high gear the right track stops. I am not sure what type of transmission this and does this use clutches?
This only occurs in high gear. Thanks for any and all help.
Problem with RH hi-speed clutch pack and/or hyd. circuit. ck shifter rod adjustment for full engagement, brakes stop power, but should show up on lo side also. on older models, used to have trouble with fluid delivery sealing rings/caps on shaft. not sure on E.
Some of the case high/low shifter spools were two piece with a snap ring to hold them together. If the ring cracked up and fell out it left you shiftless without a clue as to what happened, but the dealers knew exactly what happened,lol.
