jd 450 crawler loader power steering?
Its mounted on the front timing cover of engine driven off the cam shaft gear.All it does is run the power steering booster cylinders.
I had a look at the parts drawing,its a gear type pump,you did not say what's the problem with it,if the pump is not making pressure check on the relief valve in case its held open/spring broke etc,with gear type pumps usually the housing and end plates wear which is the main part of the pump.
AJ
