IH 3414 tractor backhoe
I need a parts supplier for a IH 3414 tractor, or someone interested in buying a 3414with a backhoe and a 3414 tractor with front loader for parts. Thanks
Supplier for what sorts of parts? I've had no problems getting parts for my 3414 tractor with a 3120 hoe on the back. Engine and tractor parts are available from generic sources, Case-IH,Komatsu, or Mahindra. I rebuilt the engine last year and put on two new hydraulic pumps and had no trouble getting the parts.
The engine if gas is a BC144, and if diesel a BD154. Distributor is a Lucas and takes the same tune-up parts as several British sports cars.
All available from any auto-parts store. 1974-1983 MG, 1975 Austin Marina, etc. You can also buy a Petronix breakerless conversion kit (they have it). My 3414 has a Lucas 43D4 distributor.
Same dist. used in 73-74 Reliant Robin Saloon and Van, and 74 up TW9 pickup
It’s a Lucas type 43D. BMW Minicooper has similar. 73-75 Austin Rover 1800, 80-83 Lotus Elite, Esprit, Distributor Eclat, 74-83 MGB, GT, Metro
IGN parts check that should fit: Listed for 1975 Austin Marina GT and 1980 MGB
BECK/ARNLEY Part # 1733880 IGNITION ROTOR
BECK/ARNLEY Part # 1716885 IGNITION POINTS
BECK/ARNLEY Part # 1725837 condensor
BECK/ARNLEY Part # 1740257 distributor cap
NAPA:
Cap - EP61 or ATM 1414036 Rotor - EP62, Pnts - CS208 or ATM 1411064 Cond-EP60, Rotor - EP62
IH book shows for later distributor - cap - 3069777R1, rotor - 3069778R1 (Standard DR158), points - 3069882R91, condensor - 3069883R91. Complete late distributor with tach drive and vacuum advance is - 3068973R91.
Older distributor, before serial # 5885, is 3044213R91. Cap is 3047513R1. Rotor is 3047514R1. Condensor is 702325R91. Points is 72326R91.
Note: 3069882R91 cross to: D103P, DR1074MV, DR2236XP, J3200407
