Trojan tractor shovel
bought this Trojan tractor shovel for handling Oliver implements and other heavy lifting cause my skid loader isn't the biggest. Like everything I buy it needs work. Wondering if anyone has info or used this model? Trans has 6 gear spots and it has the forward/reverse shuttle shift. Pretty sure its just a backwards tractor for the trans, final drive, and brakes, anyone know what tractor? What kind of fluid should be used in the shuttle shift, trans/final drive, and hydraulics? What is engine model its just a flat head 4 cyl. Anyone know where I could find a manual? tag has Machine no. G-268 model no. LHM 75. thanks for the help can post more pics if needed
The Trojan loader plant was 5 miles from me in
Batavia, N.Y. Their is one fellow that used to run their parts department. He has a machine shop and also buys and sells Trojan parts. Send me an e-mail and I will give you a name and phone number.
Used to see a lot of them around here in the early sixties. They seemed to hold up pretty good. But, what makes parts a little hard to get is the company changed hands several times. If the fellow I mentioned above does not have the part I have a list of old time Trojan dealers. Could dig them out and send them to you.
(ps I have 2 of the 1900z series loaders and like them).
(quoted from post at 21:42:35 08/03/13) The Trojan loader plant was 5 miles from me in
an you send me that info also.I live in Alden NY,not far from you and own a Tractor shovel model 124
We had one like that for about a year around 1965, gramps bought it for a larger loader than the old Fordson Major Diesel for loading lime spreaders in Wallace NY. Was a little light on traction for loading out of a stockpile, he found a 4WD Michigan 75A and the Trojan got parked out back. IIRC it had a Continental Four. Should make a pretty good yard dog
