Ken Macfarlane
Anyone know how these little buggers work? There is a grease zerk in the 45 adapter. The 45 adapter seems to be a swivel as you can't remove it it just turns and turns. There is a bigger 24mm hex bushing that the grease fitting is installed in that also just spins.
I've only put tracks back on a dozer and a mini ex and they had separate drain with a plug and a grease nipple to fill. No spinning stuff, no valves etc. Manual contains no info.
