remove fuel injector???
If you haven't already found the help you need just post under Case on this forum. There are a lot of helpful guys there.
The injector pulls straight up after you remove the leak off on the top and the high pressure line off the stem,if its tight and they usually are there is a special tool Case do that attaches to a slide hammer,I usually use a cobbled up one that screws into the leak off,you will need something that has the same thread to attach it to the injector [piece of threaded bar] you can use a piece of tube with a slot cut out of it for the stem of cobble up a support like in the drawing.
AJ
[/img]
I am learning about injectors as I go here! lol I got 'em out and now find out I have a damaged one. Trying to locate a replacement and they can't be found by neither the local diesel shop OR the case dealer.
I am going to try John Deere and see if that works.
