Case 350 crawler pump timing
Anyone know where the timing marks are, and what
the static timing should be?
Been asked to put a pump back on and don't have a
clue what references, if any, may have been used
when it was removed.
# 1 cylinder on compression stroke,timing mark on flywheel to 8° before TDC,the timing window is under a small plate behind the starter and up a few inches on the bellhousing,remove the pump timing window and put the mark on the rotor and the pump body in line,fit the pump.
AJ
