I'll try to explain..... This is a low use machine..... Last summer 1st and 2nd gear worked fine including the button down shift from 2 to1, but no 3rd and 4th. In the fall it switched from no 3 rd 4th to ONLY 3 rd and 4th to no 1 st 2nd. I tried a new gear shifter, same issue. I have power to the solenoids when powering with the gear shifter, solenoids have been checked, and I have pressure in the test ports that coincide with the gears described above, pressure in 3/4 not in 1/2. I am thinking an issue in the "gear changing unit" that works with the solenoids or in the oil galleys leading to the transmission pressure lines..... Whaddya think???
