steven in Tn
when i got my dozer it was not charging, took the panels off today to pull the alternator to have the shop check to see if its working or the issue is in the wiring. there is only one wire hooked up to the alternator and thats the battery wire, there looked to be two wires that had been cut along time ago. is this a one wire alt or do the other two wire supposed to be hooked up?
also noticed the fuel primer pump next to the fuel filter is leaking, it has been losing prime and hard to start now i know why. can i buy a repair kit to fix this?
also it is blowing a good bit of black smoke when using it. i have run it 3 days and the oil level hasnt dropped, any ideas what the cause of the black smoke?
