i have a case 310 crawler loader..it has developed a leak on one of the bucket tilt cylinders and i would like to get a kit to repack/rebuild the cylinder......hydraulic fluid is expensive
are the tilt cylinders the same on the later case 310 e,f,and g's
there seems to be no problem getting kits for the later models
the cylinders on mine are tie rod type, if this is any help
if they are not the same , does anyone know where to get the rebuild packings and seals kit [case number is d 30135]
the old girl runs like a charm since ed at crawler heaven got me a new set of track chains and i added a pertronix ignition and a gm cs type alternator
thanks for your help john bars
