OIL TO USE IN TRANSMISSION AND TRANSFER CASE
lenray
On this old 1965 era industrial tractor with a 5 speed Spicer tranny and a Rockwell transfer case--what weight and kind of oil should I use???
Thank you
Most things at that time used a 90 weight gear oil. A GL 5 grade would be ok for the transfer case and a GL 1 grade for the tranny if it has brass parts in it.
