More questions on our Dresser TD-12 Dozer Tracks
mickster
New User
Our TD12 dozer does have 37 pads per track. It has the alligator master link set on each side, of which we need both sets. Additionally we need some yet to be determined number of links, several pins, all 74 pads and all new bolts. Alternatively, we would be interested in a good set of TD 12 used tracks, but we have thus far not been able to locate any. We would kindly appreciate any ideas you may have as to source of new or good used parts. If anyone can help please post or call. Jim, cell 406-360-2248
Thanks again AJ, we appreciate your help and we will sure check these sources. This is a good machine but it's very hard to find the track parts for her. We are in western Montana, USA.
Our TD-12 is contracted with the US Forest Service and must be in top condition to meet the continuous inspection requirements.
I will post the results of our search, so it may possibly help someone else that may have similar needs
Someone answered you on here the other night about late model td15b working. I started to tell you then IF you have the alligator or sealed and lube track the 15 rail is different. You need to find you a good BERCO dealer and see what he can do. I know where there are two 12 sitting because of no UC
Why is all those common size tracks right across the popular range of machine no longer available,yet there is plenty same size machines but the tracks have been changed from the old sizes,was it a ploy to sell new machines by making sure there were no tracks for the old ones,its a wonder Wing Hing has not come up with replacments.
AJ
