td7g dresser dozer
have A TD7G DRESSER DOZER OR INTERNATIONAL. HAS A CUMMINGS ENGINE WITH ELECTRIC SHUT OFF. IT RUN ABOUT 5 MINUTES THAN QUIT WILL NOT HIT ON STARTING FLUID, HAS PLENTY OF FUEL AND CLEAN FILTERS LIFT PUMP ,IS GOOD. COULD IT BE A WLWCTRICAL PROBLEM. SOLENOID ON PUMP CLICKS WHEN YOU TURN THE SWITCH ON, NEED HELP THANKS.
Is it a CAV pump that's on it,check the connection at the stop switch,it should be hot while the key switch is on,if not use a jumper wire direct from the battery,still no go remove the switch,the plunger and spring can fall out so don't lose them,sometime the rubber seal on the plunger can swell causing the plunger to stick,leave the plunger and spring out and screw the switch back in and try to start if it goes order a switch,stop it manually there is a lever in front of the throttle on top of the pump,always push that lever back to the run position after stopping the engine.
AJ
