mike clifford
Hello I have got my dozer inside and the injection pump removed.
It is a CBC 431. 3dg. Attached is a pic of the shaft that sticks out from the timing gear area.
Is the conversion pump supposed to fit to this ? Or is this shaft to be removed? Does this look normal?
The conversion pump I saw at the dealer won't connect to this .
Also the 2 blolts that hold this pump on are much farther apart than the new pump, I know there is a couple clamps in the conversion kit, is what they are for?
J D says the instruction sheet for the adapter kit is no longer available! What's the chance you would have such a document?
Any help would be appreciated
Thank you
mc
Thank you
mc
