Case G310G Crawler Loader ser #3030449
mjsoliver
Went yesterday to check out this loader. Found it with the engine out of it so I couldn't tell about it's running condition. He is putting rings and bearings (.010 over) in a 530 Case tractor engine to replace the original engine that tossed a rod thru the block. What I noticed wasn't too bad but I wanted opinions from you guys who know tracked machines better than I do. Both rear leveling cylinders appear to have been leaking some and one lift cylinder too. Repacking them is probably no big job, I assume? The dump linkages are pretty loose and "floppy" when you push them side to side. I'm guessing the bucket pins are loose too, but with it down on the ground I couldn't tell. Can the bushings and pins be replaced and how expensive and how tough is the job? The undercarriage appears pretty decent. The left side is likely original, with a spoke sprocket and idler. The track is a bit loose and the adjuster shows about 3 1/4 inches of thread exposed. The right side has solid a sprocket and idler, track looks about right tension, and 2 1/2 inches of exposed thread on the adjuster. The sprockets looks like they are aligned about the same (measuring from the frame to the sprocket teeth) on both sides. Both tracks have 33 twelve inch pads with good grousers. The underside of the tracks (is that what is called rails?) has alot of meat left. The rollers all have good shape to them and none are showing any signs of loose bearings or grease seeping out. How much adjustment is left with this much thread exposed? Is it likely that the adjusters will be frozen as the threads are rusted and only somewhat pitted. Will it hurt to heat the adjusters to free them up if they are frozen? He said the gas tank is rusty so he cobbled up a 25 gallon tank on a frame welded to the big rear weight. I'd be worried about backing into something with that tank sticking out like it does. It has a 5 foot bucket with a nice cutting edge bolted underneath, no teeth. Hourmeter shows almost 6300 hours and the machine has paint on it but it's pretty faded. He said it has had the steering clutches replaced, but he didn't say when. He is asking $4400 for it. I think that might be a bit on the high side. What is your opinion and what have I missed that I need to check when he gets it running?
sorry I have written a book here, but I wanted to get everything in so you all would get a good idea of what it is. Many thanks!!
Mike
I think you can find a better buy elsewhere , may have to pay trucking bill from short distance . Check out Machinery Traders . com
(quoted from post at 09:30:35 01/24/15) I think you can find a better buy elsewhere , may have to pay trucking bill from short distance . Check out Machinery Traders . com
There is a nice running 350 in Maryland for $6,600 , teeth on bucket , rops cage , , says it is ready to work . Needs a muffler ,says it has good undercarriage , Machinery Trader click on the word Crawler Loaders .
I hope I am allowed to suggest where to find a better deal than the one you are looking to buy .
(quoted from post at 10:36:46 01/24/15) He had the steering clutches replaced??? I don't
think so. It does not have any !
That did go thru my mind when he said it, because I thought I read in another thread that they didn't use clutches. By the way, it was the mechanic who is working on the engine that told me that, I still haven't met the owner in person yet. So how does it steer?
Please feel free to make suggestions! I am in SW Ohio and would like to find something in OH, KY, or IN. I need to go look before I buy and I could really burn a bunch of gas if I were to expand past those states. Certainly somebody has one closer!
Thanks for any suggestions!
(quoted from post at 11:36:45 01/24/15)
Let us know how you come out ?
Two brake bands on two brake drums. One on each
side of the differential. Works the same as when
you steer a farm tractor by hitting the left or
right brake pedal.
(quoted from post at 05:48:05 01/25/15) Two brake bands on two brake drums. One on each
right brake pedal.
Simple enough. That keeps power to both tracks during a turn, as opposed to releasing a clutch and applying a brake on other dozers? Thanks!
